code is to install a dpdt transfer switch. what about the neutral when the utility power comes back on could that blow a diode on the generator. also for a temp. portable set up turning off the main or pulling the meter [even both] would do the same as a dpdt switch. i know that if someone closed the main a utility worker could die. thanks e150club
