Our generator has a 120/240 Volt AC, 30 Amp receptacle that accepts a NEMA L14-30 plug. It has two hots (X and Y), a neutral, and a ground.
Our well pump is 230V, single phase, 5.9 Max Amp, 1/2 HP. It has a red (L1), black (L2), and yellow (ground).
The required wattage for the pump (including surge) is well within the capabilities even with our existing load on it.
My brother in law sent me this. I thought it would be an interesting question to post as I have not heard the same answer from anyone I have asked. I would appreciate a good way to explain this to him in lamens terms.
I was planning putting a plug on the line from the pump and a receptacle on the line to the breaker. I can leave the pump plugged into that for daily use and plug it into an L14-30 generator extension cable if we lose power. That way I'm not backfeeding into the lines.
Someone told me I could just not use the neutral from the generator, but I wanted your take on it.
If I can ignore the neutral, is it a problem to have that L14-30 plug connected into it with nothing connected to the neutral on the other end?
