Can generator connects directly to ATS without OCPD?
Are you asking can they ?
Or should they ?
:rant:
Hi Cletis !
Please do not confuse Mr.Sleem with another member.
I believe you need a disconnect so the generator does not send power to the transfer switch when the systemis being worked on
Sorry when I said disconnect I meant with overcurrent protective device since hat was what the op asked... Thanks for clarifying thoA disconnect is not needed for that reason but I do believe OCP is required to protect the ATS.
