ivsenroute
- Florida
Does anyone have any ideas for customers who have a heat pump system in a northern climate when it comes to standby generators?
It appears as though the cost vs benefit is questionable when it comes to heating the house due to the kW usage. For example a recent heat pump that I looked at had 3 elements in the kit at 5kW each and this is before you take into consideration the fan motor, condensing fan motor, compressor, hot water heater (electric), septic pump tank, well, etc.
I think it would be easier to have pellet stoves installed so you can get a smaller, less expensive generator. In this case a 20kW Generac would not be big enough for what he wants done.
Thoughts?
Thoughts?
