aarifisher
I need to buy a 400 amp generator for a local grocery.
So i was looking at the specs. Of a 130kw generator and the rated amps is 451a
Now, I made the calculation as 130,000 / 360 = 361amps
So I contacted the manufacturer and this is the answer i got
(130,000 (kw) / 208(VAC) * 1.73 * 0.8 (Power factor) = 451A output)
Now, to my understanding the power factor should reduce the output.
Can someone please explain?
Thank you
Thank you
