I have a residental load calculation at 278amps. They recommend going 25% larger for a generator. Which is 347 amps. an 80 KW is rated at 320 amps. A 100 kw is rated at 417 amps. By the numbers I should use the 100kw. Should I? The 100 kw is 6,000 more which is not the end of the world. I have been told the load calculation for a house is oversized allready for one reason or another. Would like some outside input. Thanks
