Other than trying to enforce the difference between temporary and hard wiring, is there any technical purpose behind the rule requiring cord-and-plug connections on portable or vehicle mounted generators without a ground rod?
Reason being that the particular instance is in a large mining operation. We use portable cords extensively (up to 300 MCM/7200 VAC). We have lots of "small" 30 HP or 50 HP temporary dewatering pumps. Although plugs are more convenient the general tendency with the electrical group is to hardwire the cords due to reliability issues with the plugs (corrosion and water).
It seems relatively silly that the only difference between wiring up a portable generator with a 30-50 HP pump attached and requiring a ground rod is whether or not it has a plug connection.
Ground rods are a bit of a problem because the soil on the mining pit floor has very poor conductivity. The vast majority of the power distribution outside of generator-supplied uses high resistance grounding systems with grounding grids established at the substations. Everything in the pit is grounded via 4-wire wye connections back to the subs.
