sparkync
- North Carolina
I have a customer who wants to put a "30 amp generator inlet box" inside his house below his electrical panel. Eventually he is going to put in a "power bank", where the "inlet" is, and plug into it, then run a cord through his window outside to his gas generator. Right now his plans are: using a "120 volt generator plug adapter" to plug into the inside "inlet box", and run his cord through the window to his generator, just in case he has a power outage until he can get the "power bank".
When he gets his "solar power bank" installed, the outside generator will be used only for "recharging" his "power bank". I've never done one exactly like this. Can this be done according to Code, with the "inlet" placed inside the home, even though the generator will be outside? Thanks
And forgot to say, that a "inter-lock" device will be installed in his "electrical panel".
