I am a electrian with a waste water plant and we had a problem with our new generator.We got a stand by 700kw generator to provide emergency power.The connections were tied in to a juntion terminal were the existing generator was connected.My partner and I connected the 480v with a ground from the standby generator. I checked phase rotation on both existing & stanby gens.Started the 700kw stand by with the existing generator disconnected. When our plant transfer switch connected to emergency power the lights(fluorescent) flickered and we lost 12 electronic ballasts only on 1 circuit.The system we have is 480/277 4wire.We checked voltage & 60 cycles at the lugs in the stand by gen it was ok.We both considered voltage regulation but the gen was ok.When we fixed the plant new gen everything ran fine. My partner and I both licenced electricians have different theories.My concern is were we connected the gen.From the tranfer switch is boy, neutral & gr and the gen standby had boy with the ground connected to the metal large juntion box.I can go on and on what is your take on this. thanks one hard working stiff....
