Got a customer who does wood working, and has purchased some 480V/3 equipment.
20HP Planer, 15HP Edger, etc....I figure he needs less than 100A to run what he wants.
The service into his building is 240V/1/60, and 3 phase is not available anywhere near his site (5 miles away).
He's also got a 350KVA 480V diesel generator that he wants to use to power this equipment.
This (used) generator has a 100A 3 pole fusible disconnect mounted on it's exterior that's apparently been used in the past as the disconnect for this generator. The conductors from the generator terminals to this disconnect are #2cu.
This seems to be a violation of 445.13.
I understand that the conductors from the generator output to the first overcurrent device must be sized for 115% of the generator capacity.
In this case 500A...correct?
Does this mean that the generator disconnect has to be rated for 500A?
That may be a stupid question
My mind says yes, but I'm having a problem understanding the reason.
All I need is 100A from this generator.
Can I not just fuse my feeder from this generator at 100A to power a 100A MLO panel inside the building?
If I have to set a 500A disconnect at the generator and feed it with 500A cable, can I then use the 10' tap rule to power a 100A Main breaker panel from this 500A disco?
I tried to sell this guy on using inverters to get 3 phase power for this equipment, but he's not interested.
This guy is a multi-millionaire that made his money building, owning and operating large equipment, and this wood working is just a hobby..albeit a large one.
He's quite a character.
He wants to use this generator, and this 3 phase equipment.
What would you do?
Any ideas are appreciated.
steve
What would you do?
steve
