Fulthrotl
~Autocorrect is My Worst Enema.~
- E
i've got a few... i'm at the design stage for three whole house generators.
everyone wants these, it seems... they are the new status symbol around
here.... i'm good with that...
i'm looking for the quietest units available.... 1800 rpm versus 3600 rpm
is preferable.... who has installed stuff you are impressed with?
in one case, the customer is looking for dual fuel, NG and propane. is there
anything on the market that does that, that you'd recommend?
the panels in each case are 200 A.
recommendations on automatic transfer switches.... in two of the cases,
i'm looking at going out the back of the service into the garage, and putting
the transfer switch there....
and the last fugly part, shedding loads... i'll want to drop the two A/C's,
the pool heater, but i suspect they are gonna want to keep everything else
alive.... what's the best way to accomplish the load shedding other than setting
a subpanel and moving conductors... that can be done, but is there a better
solution?
i can put ice cube relays to interrupt the a/c compressors from starting, and
the same with the pool heater.... what about other loads? suggestions?
thanks for the help...
randy
solution?
randy
