Re: Generator sizing
A generator is sized based on the load it has to support.  NEC lists the mandatory emergency load,
 that must be supported by the generator.  Beyond that - it is the facility owner's preference and  design/operations engineers' opinion on what has to have the back up power.  Once you know the load
 it depends on the type of load: for a non-motor load the safe way is to have generator's KW equal to the total load KVA - because you would not be able to calculate the load's power factor exactly.  If you have motor load, than you have to use one of the available software
 (and there are plenty of them) to account for the voltage drop due to in-rush current.  Some generator manufacturers have a program on they internet site (Genarac for example) where you can do it for free right off Internet.
