I'm not sure how to ask this question. I'll try and maybe have to clarify later.
I'll be referring to Stevenson's Elements of Power System Analysis, 4th ed, Ch 10, pg 256. The following is given: generator with internal voltage Eg, synchronous reactance Xs, external impadance Zext, and load impedance ZL all in series. Current IL flows through the circuit before the fault. The companion to this is the faulted version using subtransient internal voltage Eg", subtransient reactance Xd", Zext and ZL. With open fault located across the load imopedance. IL is shown to flow through this circuit as well.
The book states that for a different value of IL, Eg will remain unchanged, but a new vaule of Eg" would be required.
This is where I lose it. If the current changes (assuming load and external impedance remain unchanged - this is not stated explicitly in the book), then one of 2 things must be true: 1-the internal voltage of the generator must change, or 2-the synchronous reactance must change.
The book states that the generator internal voltage remains unchanged. So how does the synchronous reactance change in a generator?
