A customer wants to run a machine shop at his residence from a welder generator. This will generate 3 ph 480v 30amps, and 120/240v single phase 30amps. Their will be no electrical service to this detached garage.
The plan is to set this generator on a pad 2 ft from the outside of the building. Use 2 seperate twist lock cords...one from 480v and the other from the 240v. I would use so cord to an outside j box on each then go thru the wall directly to a panel on each. This means their will be a 3 ph 480v panel and a 240v single phase panel.
From the 480v panel I will power 3 pieces of equipment.
From the 240v panel I will power lights and outlets.
What are the requirements for a code install. Im concerned about having 2 sources of power....yet their still comming from the same generator. Both of the sources will have twist lock plugs to disconnect power if needed.
Am I missing any show stoppers here?
My other option that is very costly:
Get a 480v 3ph to 120/208 3ph delta wye step down xfmr and power a single panel for everything.....equipment and lights/outlets.
All of the equipment is now setup for 208v 3ph but I plan to replace starters and re wire motors to support 480v if I go that route.
Thanks in advance
Thanks in advance
