Generator Transfer Switch
scottau
When using a whole house generator with a automatic transfer switch, is a service disconnect required between the meter and the transfer switch? If transfer switch is service entrance rated does this change anything.
Re: Generator Transfer Switch
If the transfer switch is rated for service use it should be considered the disconnect also since it will have 3 positions.
1) Utility
2) Off
3) Generator
Dave
Exactly!
Although, Scottau didn't say if his Transfer switch is rated for service use!
hmmm?
If the transfer switch is service rated and contains overcurrent protection, no disconnect necessary. If it doesn't contain overcurrent protection, you would either need a disconnect with overcurrent protection ahead of it or you could install your protection downstream from the transfer switch "immediately adjacent" to it. This all assumes that the transfer switch can be disconnected manually from both supplies.
Must it be an over-current device, or merely a disconnect?
Okay, it looks like you mentioned this after the OR.
[ August 25, 2005, 06:44 PM: Message edited by: LarryFine ]
From a servicing and testing standpoint, I would recommend a service disconnect before the ATS.
[ August 25, 2005, 07:27 PM: Message edited by: paul ]
Yes I did say the switch was service rated. Can anybody give code reference with their reply??
Do I need overcurrent protection at this point?
Scottau,
445.18 Generator shall be equipped with a disconnect.
702.6 Transfer equipment must be suitable for intended use.
You should read both of these short articles yourself.
I don't see where additional disconnects/equipment are needed.
frank
The issue is not between the generator and the transfer switch, but between the meter and the transfer switch. Article 230 section V and VII.
From what I have been able to find out in this situation the transfer switch can be used as a service disconnect only if it is service rated and has overload protection, otherwise I will need an additional service disconnect.
scottau,
You are correct in that the x-fer switch has to be marked correctly to be used as a service disconnect, 230.70(B) and (c).
Also see 230.91 for location of service overcurrent device.
If your x-fer switch meets these criteria it can be considered as the service disconnect.
I believe that mvannevel answered the question quite well.
Pete
