tonype
- New Jersey
60-amp 2-pole breaker in main supplies transfer switch (gasoline generator is other input). Circuits breakers in the main panel have been disconnected - replaced with ones in the transfer switch panel. However, circuit conductors are then routed from the breakers in the transfer switch panel back into the main panel and spliced to the original circuit conductors with wire nuts.
In this configuration, the panel seems to be a raceway for the conductors, which is something I thought is a no-no. Am I correct?
