I was wondering how a generator was able to supply vars for voltage support on a downstream load?
I'll use an example system of a voltage source connected to an inductive impedance transmission line and a load.
If the load is an inductive load then it will draw inductive reactive power and this lagging inductive reactive power across the transmission line will result in a voltage drop at the downstram load/bus.
However if a large enough capacitor bank was installed at the downstream load and was enough to cause a leading current and leading capacitve reactance across the transmission line then there will be a voltage rise at the downstream load/bus.
I was wondering if rather than placing a capacitor bank at the downstream load if you could configure the generator to supply the leading kVARs and thus cause the same voltage rise at the downstream bus load? So rather than the downstream capacitors causing the leading kVARS, the generaotr would be supplying them? Is this possible? Is this similar to how generators can be configured to provide voltage support?
