Hello All:
Can we adjust the generator voltage output to compensate for voltage drop, if so what is the percentage? The generator is 800KW, 480Y/277V and about 400ft from the building. Other wised I might need to increase the conductors size.
Thanks,
Is the load always the same?
At low load, the voltage would be very high and at varied load levels it would sway from high to some normal value.
You can always move the sense points of the field control down to the load, then voltage drop will be accommodated for by the regulator.
Are the sense points part of the ATS? Is the voltage regulator function is to maintain the desire voltage value at the load and is done automatically?
It is fairly common for battery chargers and IT equipment electronic power supplies to have terminals for remote voltage sensing as part of their standard configuration. If you do not need to use the remote sensing you just jumper the sensing terminals to the output terminals.
Is there equivalent built-in provision for remote sensing in standby generators, or would it require field modifications?
