A contractor wants to wire a Generac generator to a home using a manual interlock in the panel,instead of an automatic transfer switch.The customer is trying to save money.When power goes out, the generator will come on automatically,but the power will not be transferred to the panel until the customer manually engages the manual interlock in the panel and then select the loads they want to run.Is there any code issues with this type of set up?I have never seen it done with an automatic generator.Any relevant code numbers will be appreciated.
