Hello, I do generator work, and I have a question. If I have a generator and the main breaker inside is a 100 amp, 240 VA, (generator rated at 19.5kW.) Yet my factory sizing guide says it will produce 210 amps, at a 30% voltage drop. (210A X (240X0.70) = 35,280 watts out of a 19,500 watt generator!
To me that approximately 35,280 watts of power, 210 amps is over double the 100 amp main breaker. Am I correct, a inductive or any load exceeding 100 amps or 24,000 watts will automatically trip the 100 amp breaker at 240 VAC, or can it really supply 210 amps? I have people trying to start large AC units with a LRA of 168 amps, I don’t think that’s possible, especially with the 30% voltage drop.
In other words, how fast does a 100 amp main breaker trip with a overloaded? I am sure it depends on the total wattage being used, Can’t seam to find that answer anywhere.
Thanks...
Thanks...
