Generator
Generator
  • To confusing?
    Votes: 0 0.0%
  • Wasnt really interested.
    Votes: 0 0.0%
  • Total voters
    1
  • Poll closed .
djtazjr
Article 445.18 requires a disconnect for generator conductors feeding branch circuit, with the exceptions of the (1) and (2).
I am puzzled? I came acrossed an inspector today that said this requirement is needed even if the gen-set has a disconnect with it, however the switch isnt "readily accessible".
Any further comments of others.
What code version is this jurisdiction following?
When the code requires a disconnect to be readily accessible, it states that. I don't see the requirement in this case, when mounted ON the genset. Ask him to quote chapter and verse.
Is this generator inside or outside? If outside then NEC requires a readily accessible disconnect outside or immediately inside the building. He may be treating this as such a disconnect.
