Generator
Big Guns
I was just wondering if anyone has come across my problem, I just installed two 14KW Generac Guardian Series standby generators one of them started up the way its suppose to, the second one ran in the manual position, when I put in the automatic position it displayed RPM sensor loss, its locked out in this position, I have reset system by disconnecting battery and removing the fuses, I also took the wire off of T1 and started the process all over and its doing the samr thing, All my voltage is correct the battery is between 12 and 13 volts all the wires are connected, Supposedly the gas pressure is correct. I'm confussed and clueless...
I haven't messed with a generac in a while but I remember there being a sensor at the rear of the engine for RPM sensor loss that we would take loose to for testing purposes. But if I remember correctly it would start and then shutdown.
Maybe Ceb will check n today and see this. He has a bunch of Generac's that he keeps up with and he has probably seen what is happening to you before and can tell you what to do.
