paul renshaw
- Cordova, Maryland
This situation was proposed to me. A single family dwelling with a 400A service, two 200A panels fed out of a meter. The owner wants to install a 200 amp xfer switch outside and feed one of the panels through it, with the two sources (util, gen) feeding the xfer sw. Are there any code problems with doing this? What about disconnecting means? The generator is 15 kw, can that be fed into a 200A switch? I had just never heard of this particular installation. I suggested putting in a seperate, smaller panel and xfer sw and moving the loads he wants on the generator there. Thanks
