Given the formal definition of power factor as the instantaneous power integrated over time divided by the product of the RMS voltage and the RMS current, you can prove mathematically (just a little algebra and a little calculus) that PF cannot be greater than 1.Can you have a power factor of above 1 ? If ot above one, If kw equals volts x Amops x 1.73 x power factor what is wrong with using a power factor of 1?.I never remember hearing of having a power factor above 1 .
You can use a PF of 1.0 if the load is purely resistive with no reactive components and zero harmonics. Not altogether common, at least in my experience, to get that.Can you have a power factor of above 1 ? If ot above one, If kw equals volts x Amops x 1.73 x power factor what is wrong with using a power factor of 1?.I never remember hearing of having a power factor above 1 .
Yes, but close to zero.You can have a power factor that is leading instead of lagging though.
A circuit with a capacitor only would have a leading power factor.
That depends on the KVAR of the capacitor just like power factor of a motor depends on KVAR of the motor.Yes, but close to zero.
I was responding to yourThat depends on the KVAR of the capacitor just like power factor of a motor depends on KVAR of the motor.
If you have a motor with KVAR of 10 and apply 20KVAR correction capacitor - you still end up with a net of 10 KVAR in your circuti - but it went from lagging power factor to leading power factor.
comment.A circuit with a capacitor only
Ok. I was assuming a circuit with a voltage source thoughI was responding to your comment.
PFC has a voltage source.............Ok. I was assuming a circuit with a voltage source though
As others have said, PF cannot be >1.00. PF is a measure of how well AC voltage and current are aligned in the time domain. If they are perfectly aligned, PF = 1.00. If the current waveform shifts either way relative to the voltage waveform, PF < 1.00.Can you have a power factor of above 1 ? If ot above one, If kw equals volts x Amops x 1.73 x power factor what is wrong with using a power factor of 1?.I never remember hearing of having a power factor above 1 .
