Confused when the genset output breaker is sized larger or smaller then the normal feeder and panel served (these are examples). I'm thinking if the genset output breaker is smaller (say 100A cb with a 200A normal system and 200A main breaker N/E panel), keep the feeder to the genset the same size as the normal source. All would be rated for 200A except the genset output breaker. However, if the normal feeder is rated for 100A and the panel served has a 100A breaker, but the genset output breaker is 200A, does the genset feeder get sized to 200A up to the transfer switch or also from transfer switch to the panel? Or does the system need to be upgraded to all be 200A rated? What NEC articles would be applicable to determine and this all is after the generator output breaker on the genset.
