jbgood60
- Arlington, tx. U.S.
When I found my box where four conductors are connected to the homerun I removed power and separated all the wires, when I check for continuity from my homerun wire to ground/neutral I have none, same goes to the remaining conductors.
But when I put at least two conductors (any two) back together I get an intermittent beeping on my multimeter which to me indicates continuity.
I have spent 4 days chasing this problem down, I'm at a loss any advice would be appreciated.
A little more back story, there is switched and non switched fixtures (night lights and exit lights from emergency panel) from two different panels in the race way ( which I thought was not allowed by code), separate neutrals and hot wires. When we check neutral to neutral and neutral to ground from the different panels we have continuity steady beep on multimeter, when we check neutrals to hot wires we get the intermittent beeping.
Again when I found the box where the conduits come together and start into one conduit I can separate the conductors and everything is clear.
I can check one circuit heading to regular panel all clear, but checking the other circuit heading to emergency panel I get the intermittent beeping till I separate the 4 conductors tied to my homerun. One more thing, I get this across 11 of 14 fixtures.
Hope I making sense,
Thanks in advance for any help.
JB
JB
