GFCI 250V breaker: What to do with neutral?
JAZ
New member
Hi, All:
I'm wiring my shop with three 20A 250V GFCI circuit breakers. Each breaker goes to a single receptacle box. There are three connectors on the breaker: Hot, Hot, and Neural. There is also a ground wire permanently attached to the breaker.
I wired 3 12AWG wires plus ground to each of the receptacle boxes.
My question is: What do I do with the neutral wire in the receptacle box? The receptacles only use the two hot wires plus the ground.
Do I just cap off the neutral wire in the box?
Do I connect the neutral wire with the ground wire?
I want to make sure this is wired correctly for the GFCI breaker to work because I don't know how to test the receptacle once I am through.
Thank you,
John
I am closing this thread, in accordance with the Forum?s rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
