Accessible, Readily (Readily Accessible). Capable of be-
ing reached quickly for operation, renewal, or inspections
without requiring those to whom ready access is requisite
to climb over or remove obstacles or to resort to portable
ladders, and so forth.
Can a GFCI receptacle be installed in a soffit? Is the code for such an application accessible, readily accessible?? I realize that the device somewhere at ground level would be a greater convenience, but putting that aside what does the code allow. Thanks.
Hmmm, receptacles in the ceiling of a garage for a door opener must be GFCI protected. Now I can reach an 8' ceiling to reset one but my wife couldnt get anywhere near it without a ladder. A ceiling higher than 8' and I could not reach it. How is this soffit any different than a 10' garage ceiling?
In my opinion you can no longer put GFCIs on garage ceilings.
I agree that its a ridiculous thing to do for sake of convenience. When you say 'no longer' that implies a change in code wording at some point. Did readily accessible once say accessible?
I say you can no longer put them on most garage ceilings, if the ceiling is very low you may be able to.In my opinion you can no longer put GFCIs on garage ceilings.
One problem here is the art 100 definition of readily accessible does not give a maximum height restriction.
It does say "or to resort to portable ladders, and so forth", but that means a person 7 foot 2 tall typically has more places that are possibly readily accessible then someone only 4 foot tall.
I'd probably use 6-7 as well for same reasons.Kind of a slow day at the forum today.
Of course, lets split hairs. I believe that most building codes have minimum ceiling heights in new construction, anything goes in retrofits.
In my opinion that will be up to the inspector / AHJ to decide regardless of the installers feelings. If I was an inspector I would use 6'-7" as the magic number taking that hint from 220.24(A) and 404.8(A) etc.
You never seen a storage shed that has low ceiling and still has GFCI requirements?You don't build a home to the height of a single person. That would be like telling the inspector I do not need a receptacle on a wall that's only 5' wide because I will never put anything there....I mean, come on Mr. Inspector I own the house, I built it...I never plan to sell it......I don't want that receptacle on the wall.......its mine...mine...mine...
Inspector replies - Here's Your...Your...Your red tag...call me back when you have the receptacle added. Have a nice day !
Sorry...bad analogy but again you can't build it for someone who may be 7' 2" tall...when they may be married to someone who is 2' 7" tall.
There is not going to be much room under a garage door opener mounted to a 6' 7" ceiling. And it sounds pretty dangerous too.
