e.man91
- California
I know in years past, all AFCI circuit breakers could not share a neutral, so you couldnt run a 12/3 for 2 circuits. Now ive seen some that can share a neutral, but the manufacturer requires you to use a handle tie.
My question though is regarding the GFCI/AFCI outlets. Can these be used to protect 2 20amp circuits run with 12/3? Basically im trying to avoid using the full sized circuit breakers in a tight sub-panel.
Thanks.
Thanks.
