...a pool installer installed 2 circuits , one 2 pole gfci circuit breaker for circulation pump (220v), and a single pole gfci circuit breaker for lighting/outlets and fountain(120v).
The 120v circuit from gfci circuit breaker in panel goes into a junction box near pool area, and than is connected to 2 separate gfci outlets, one gfci outlet serves a fountain ( cord and plug) , and the other gfci outlet serves the lights (one light inside pool and another street lamp type light), both switched lights where put on the load side of the gfci outlet.
My question is why would they install gfci outlets if it is already being fed by a gfci breaker at its source? I can't see why, but would this effect the functionality of the gfci circuitry? Have stray voltage that is an issue around pool area, specifically the pool deck and water .
