electricalist
- dallas tx
customer has gfci breaker that feeds 12 42 watt 4 pin florescent[ i believe 7in] cans. this is in a country club. 5 cans are in a locker room that has 2 sinks[ gfci outlets @ sinks] on seperate circuit. 5 cans in changing room. 2 are in shower.
each room has 1 single pole switch. in each room 1 can is a emergency / night [in case im saying it wrong,,,can is wired to stay on until power outage then battery takes over]
can over shower has shower trim, e can does not. shwer is only ada min,,about 4' wide 15 ' long,, e can is in center of door and is about 12 ' from center of shower, switch is imediately to the right inside door,,,,10 ' 6 " from center of shower....this lighting circuit is on gfci breaker because shower switch was last switch fed and the glass shower wall seperating shower from switch was never done.
maintenance man called said breaker trips some time between evening and morning. [ 5 pm and 5 am ]... i blanked off switch in shower, it showed no signs of having been wet , but i gottastart some where,,, its still tripping.
any suggestions,,,,,,,the problem being ,,how good am i at finding the actual problem, if it trips due to water then its doing its job,,[they should pay for service calls,,this is by plans new work] if its something else then we warranty it..so i need to find it pretty quickly....
as always thanks
as always thanks
