John McCann
New member
I'm working on a project in Afghanistan and we have 120/208 supply for the common electrical equipment used here at this site. We were shipped some exercise machines that require 230V/neutral. I plan to feed this equipment from a separate 230/416V power source through a 225A QO Square-D panel that we have on hand using QO GFCI branch circuit breakers, with a current rating of 20 Amps. These single pole GFCIs are rated 120/240V. Will these work for the 230V application? I need clarification on that please! Because this is considered a damp location (tents) we are pushing for the GFCIs. Is personnel protection at 5 milliamps/120 Volts the same as 5 milliamps/230 Volts or does it have to be 2.5 milliamps at 230 Volts (equal power) to obtain the same protection? We are in a very remote area and materials/information considering multi-voltage applications are difficult to collect. Any help here will be apprieciated!
