Brownsound
- Toronto Ontario Canada
Hi everyone,
i have several runs of 208v heat trace cable (single phase 2 pole, think of it as 220v or 240v, whatever makes sense to you based off where you're reading this from), which will be controlled by a contactor. The cct is being fed from a 2pole GFCI breaker set to trip at 30mA. They have added additional runs of heat trace cable and now are out of poles on the contactor. The engineer has suggested we only switch one of the legs of the heat trace cable on the contactor to allow us twice the contactor capability (so our 12P contactor could switch as many as 24 runs of heat trace cabling). I think switching one leg of the circuit might cause the GFCI to trip on inrush (if the 'cold' leg of the cable draws more than the 30mA difference the GFCI allows). Has anyone run into this ? I've never worked with heat trace, 30mA GFCIs OR 'single legged switching' so I might be overreacting - if anyone has had this experience please advise
