ShadowSparky
- United States
This has me stumped so I thought I would reach out here and see if anyone has run into this.
I went to do a service call about some pool lights not coming on and discovered a bad time clock and pool lights on a regular 20 amp breaker shared neutral with the landscaping lights around the pool area.
Moved the landscaping lights to there own breaker, pulled a new neutral for the pool lights and installed a new time clock and a 20 amp GFCI breaker for the pool lights as well.
The time clock uses its own circuit to run and just makes a contact for the pool lights. I am having trouble with the GFCI breaker tripping. But when I come over and reset, turn on time clock manually they all work fine.
My only thought is that the time clock gave a hardy spark when I turned it on. It is nothing special just a standard two Pole time clock. There are 6 Pool lights.
I thought about springing for a digital time clock, but am not sure if this will help.
Thanks
Thanks
