I have a 2 pole 20A GFCI breaker feeding a boat lift that wont quit tripping! I can use the lift anywhere from 2 to 20 times before the breaker trips, but sooner or later it does trip. The control box was replaced after a storm ruined the original and the breaker tripped before and after, so im sure its not that. The line from the breaker to control box has been replaced and is completely waterproof. There is a sub in the boat house that feeds another sub at the dock, which has this GFCI breaker. The sub in the boat house is fed with only a three conductor cable therefore the sub at the dock has the same. I plan on feeding the fourth wire anyway to isolate an insulate ground from neutral. My question to you is...Do I need to feed a fourth wire throughout this system to solve my problem or is there another possible issue?
