enireh
- Canyon Lake,TX
I came across a two pole 20 GFCI breaker servicing swimming pool equipment the white wire that is part of the breaker out of the box, was attached to the neutral bar but no wire was in neutral lug on the breaker. I changed it out to a new one and took the one ground wire going to the equipment and put that into the neutral space on breaker, tied white wire from breaker to ground bar and it trips, so I took it out and installed it back on the ground bar also and the breaker holds. The old breaker was tripping now and then and was a bit weak, also it has a 15.6 amp load so that may have worn it down over time. input?
