GFCI Breaker
rbeach29
New member
elmira, ny
Installed a 2 pole 30 AMP GFCI breaker. This supplies one dedicated 20 amp breaker for an espresso machine. It is wired with 10/3 mx cable. The beaker trips immediately if the outlet is in the box. If the outlet is not in contact with the box, via the screws, the breaker stays on and does not trip. Once the outlet makes contact with the box, it trips. As far as I can tell, there is no ground/ neutral issue, and no short can be found. What might be causing the breaker to trip?
You need to consult with a local EC that can help you trouble shoot your circuit. With that said I am closing this thread in accordance with forum rules.
* This NEC? Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Roger
