Greg1707
- Alexandria, VA
- Business owner Electrical contractor
A 25 year old GFCI circuit breaker is tripping in the panel. I removed the GFCI breaker and connected the circuit to a conventional breaker. The breaker did not trip. At this point it seems there are two possibilities: the GFCI breaker is defective or the breaker is functioning properly and there is a problem with the circuit causing the breaker to trip.
What are the odds on these two possibilities?
Failing to make the correct choice will result in an unnecessary trip to the supply house.
