I was wondering if an engineer could tell me how quickly the current balances in a GFCI circuit since it seems to me that the load fluctuating from a drill motor for example would be tripping the thing, although it doesn't. Also, why does the GFCI read current as equal, when that to me would imply that the energy is not being used in the device but rather just floating downstream to the POCO return.
In my mind, it seems that a 120v SP 15 amp device is using 15 amps. So how can 15 amps show on the neutral if it was consumed in the device?
