GFCI Effectiveness
102 Inspector
N/E Indiana
Inspector- All facets
Situation - Accessory building 200 feet from principle structure. Homeowner wants to run 10-2 UF for voltage drop, but protect it from a 20 Amp GFCI receptacle mounted exterior on the side of the main house. Is there any distance of load side conductor where a GFCI receptacle losses it capabilities to work properly? Does a circuit breaker provide better protection for this situation. I am an inspector with concern, not asking for installation advise.
If coming off of the load side of the GFCI, the length of the conductors is not affected by ground-fault operation. The only issue would be voltage drop. Using a GFCI breaker would protect 100% of the branch circuit. If using a GFCI receptacle, only the conductors connected to the load side are GFCI protected.
No "loss of effectiveness" from cable length, but a good chance of nuisance tripping due to capacitance.
I suggest supplying the run from the line-side terminals, which means burying the cable 18" instead of 12"
Going extra depth makes sense instead of GFCI protected circuit. Would still comply with Table 300.5, Column 1 for direct burial cable. Same would apply if a standard circuit breaker were installed with no additional outlet, just straight shot. Thanks for making think outside the box on approvals.
Column 1 for direct buried cable would require 24" of cover.
In hospital ER LIM panels you are not allowed to use type THHN/THWN standard building wires to any of the receptacles. Should use type XHHW-2 low leakage cross linked polyethylene ( XLPE ) insulation. When GFCI's first started out in early 1970's the supply house said if you install a GFCI on long circuit runs that could have problems with nuisance tripping.
Hello, sir. This message has nothing to do with the post, but it's the way i found to reach you. In a post from 2022 you said that you were having trouble to read the DC-link voltage from ABB drivers and that ABB woudn't answer how to do it. Well, i'm facing a similar problem with a ACS800 driver. Coud you, please, tell me how to read the DC-link voltage via the display screen?
Retired a few years ago and never worked on an ACS800 ABB drive. We had ACH550 ABB drives but will try to help you. First off ABB continues ( in my opinion) to still be a very difficult company for tech support or answers over the internet One search for accessing ABB DC Buss voltage on drives supplied over 3/4 million useless answers. No mention of DC Buss voltage in worthless 54 page user Manuel. Downloaded the ACH550-1 471 Page user Manuel and stated on page 172 to go to group 1 then into parameter 0107 to read DC Buss on the control panel. For a drive supplied by 480 volts three phase DC Buss = supply Holts × 141 = 676.8 volts DC . ( Usually 660 to 672 volts).One u tube vidio had that at least some ABB drives have a terminal strip where you can measure the DC Buss voltage with a meter. The old Danfoss VLT drives had an easy to access terminal strip to take DC Buss voltage readings but not on FC 100 & 200 Drives. Note for some reason the Danfoss DC Buss readings were always within a volt or two between reading on the LCB ( Local control panel ) and no matter what meter I measured it compared to LCB.
