In the past, when wiring pool & spa installations, I would use a subpanel at the pool equipment to handle all the associated loads. Instead of using individual GFCI breakers for the branch circuits I would use a GFCI breaker in the main panel to protect everything in the pool panel. Specifically I would use a Square D QO250GFI breaker with a neutral connection. Someone informed me that the installation is incorrect. Do any of you know if this set up is a violation of the code or the manufacturers spec. I called Square D and got two different answers and can?t find any reference in the code that dis-allows my practice.
