- Wisconsin
- PE (Retired) - Power Systems
Re: GFCI from a GFCI?
wiered, UL seems to think the TEST button is a valid test of the entire GFCI. From the UL website:
To properly test GFCI receptacles in your home:
Push the "Reset" button located on the GFCI receptacle, first to assure normal GFCI operation.
Plug a nightlight (with an "ON/OFF" switch) or other product (such as a lamp) into the GFCI receptacle and turn the product "ON."
Push the "Test" button located on the GFCI receptacle. The nightlight or other product should go "OFF."
Push the "Reset" button, again. The light or other product should go "ON" again.
