GFCI Hospital Grade/Residential
goldstar
New Jersey
Electrical Contractor
Re: GFCI Hospital Grade/Residential
Wow :roll: , competition must not be too stiff in your area if you're installing hospital grade GFI's in residences. As Dave said, as long as you have the proper OCP AND if your customer doesn't mind having the green dot on the face of the receptacle, there's no reason why you can't use it. It's overkill but you can use it.
