Upon inspecting a home recently that was built in 1950's where the electrical was upgraded to 200amp / 240 v service I noticed the following.
In all rooms there was GFCI outlet and all 2-prong outlets were down-line linked together for the room on this circuit.
1. When using a standard (el-cheapo) tester it showed that all grounds were open.
2. When using a GFCI tester on the GFCI outlet the GFCI would NOT trip.
3. When pushing the "test" button on the GFCI outlet it WOULD trip and cut power to the outlets that are linked down line.
From a home inspector stand point are these outlets correctly wired and I should not necessarily believe my cheapo tester ?
And since they are linked with GFCI outlet are they fine without the ground or should that be written up as an issue. While not near water as in the kitchen , but water is still possible since folks use humidifiers etc for babies etc...
Your opinions and expertise are appreciated.
Thanks
Thanks
