G Gategator37 Senior Member Oct 4, 2010 #1 Should all receptacles inside of electrical rooms be GFCI? If so, can someone point out the code reference. Thanks
480sparky Senior Member Location Iowegia Oct 4, 2010 #2 Not a requirement. May be a job spec. But would be a good idea.
charlie b Moderator Staff member Location Lockport, IL Occupation Semi-Retired Electrical Engineer Oct 4, 2010 #3 GFCI requirements are in 210.8. But as 480 said, you won't find the requirement there, so you can infer that no such requirement exists.
