GFCI In Kitchen question
Leos98
Westchester, NY
Hello to everyone,
I?m replacing all of the receptacles in a kitchen; when I first saw the job I though it was going to be an easy one. Not anymore!! I now discover that when the job was done, a 12-3 romex was run from outlet to outlet. At each outlet, either phase A or phase B was tap to create an A-B-A-B configuration. The problem with this is that the ground is share at each location. When I saw the job, there was two GFIs (one at each side of the sink) and that was it. I now find my self in a situation in which I do not know how to protect the circuits via GFI receptacles. I was thinking on putting a 2P GFI breaker on the circuits but I?m uncertain if this will work. I also though of installing GFI outlets in the first two receptacles in the line by breaking the neutral at each location (Neutral to LINE-IN in the first GFI, Neutral of LOAD to Neutral LINE-IN in the second GFI) Can I do this?? Please help!!
Leos98
Assuming the wiring is good than it will work fine and is an option.
Forget about any of that, you can not break the neutral without breaking the hot at the same time.
Use the two pole breaker or use a GFCI receptacles at every counter receptacle location.
I prefer the GFCI at each receptacle route but that can get expensive....but keep in mind a two pole GFCI breaker is not cheap either.
I special order LUTRON's satin devices and they are installed already. I left the two GFI for last without imagining the problem. I guess I'll do it via a 2P gfi breaker. Thanks a lot!!
Leos98
Just make sure you find the neutral for that 12/3 cable and remove it from the neutral bar and connect it to the GFCI breaker.
If you do not do that it will trip all the time.
I agree with Bob. Depending on the number of receptacles the 2-pole GFI breaker is propably the least expensive.
I know that you can not run load to line on a gfci it will trip the gfci, however I do know that I had a simmalar situation in a resturant and if you pig tail your neutrals at both gfci and land them under the line side that they will hold and will trip properly
Leos98
Be SURE that your 2-pole 20 amp breaker has a load neutral terminal. Many 2-pole GFCI breakers do not have a load neutral.
