BuilderMan
- Los Angeles
- General Contractor
Can you place a GFCI receptacle on each leg of the multiwire branch circuit if you've pigtailed the neutrals?
Pigtailing the neutral in the junction box of first GFCI so that the neutral reaching the second GFCI is completely disassociated from the first GFCI - no connections on load side of first GFCI.Your pigtailing the line side of the gfi? Correct? Load side, they will need to be separate. Two pole afci shouldn’t make a difference.
