GFCI installation question
deepdave
New User
Ohio
Computer programmer
Replacing old receptacle with GFCI receptacle. Old one has a single white wire attached top right next to the ground. And it has two black wires on the same screw on the bottom left. One I assume is the hot line because the other one goes into a switch to the overhead fluorescent. On the new GFCI do I move both black wires to the upper line side? Or do I only move the hotline to the top and connect the one to the switch through the bottom load? Thanks
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
