Maybe this will help?
The term GFCI means "Ground Fault Circuit Interrupter". It refers to a DEVICE FUNCTION that both detects a
ground fault condition, AND
interrupts the flow of current in the
circuit.
GFCI functionality
can be built into a receptacle, it can
also be built into a device that FITS into a receptacle box, but has no actual receptacle slots in it (called a "Dead Front" or "Blank Face" GFCI outlet).
The one on the right is a GFCI
receptacle, the one on the left is a
Dead Front GFCI.
(used as an example, I do not know why someone would have both in the same box...)
It can
also be built into a circuit breaker that feeds an entire circuit full of receptacles, in which case the receptacles can all look standard.
And lastly, there are
also GFCIs that are built into cords on pieces of equipment.
ALL of these things can be referred to as "GFCIs"
