Jleidolph1
New User
- New York
We ran a 40 amp service from the main house to a detached garage. Ran romex to a junction box, in the crawl space, to PVC with THHN to the garage. We drove 2 ground rods at the subpanel in the detached garage, and also bonded the gas line, which was buried in the trench with our service. There are 3 circuits in the panel, (yeah the 40A service was overkill), one for lighting, one for the heater, and one for the plugs. First plug we hit the GFCI and jump around to about 5 plugs inside the garage and 2 plugs outside the garage. The GFCI tripped to the point where it wouldn’t reset anymore. We replaced the GFCI thinking that was the issue, but the new one tripped as well. So after pulling out plugs and checking wirings, especially the outside plugs in case they got wet, nothing seemed to be touching, or wet and the GFCI reset and held. We were able to test the garage door opener, and everything was working perfect. Get a call today, that the GFCI tripped again and won’t reset. Any ideas as to what the issues would be? Figured it there was any wiring problems, we wouldn’t be able to get the GFCI to reset without it tripping again.
